[PRES] Bedford double cabine
Erwann37
Message par Erwann37 »
Oh, tu sais, après 2 land, 2 mini, 3 bedford, l'escort, une anglia (pas à moi, mais j'ai fait la méca dessus), imagine l'état du garage.........
un de nos record, 10j sans fuite sur une boite de mini entiérement refaite (avec tous les joints changés)........sur la boite, tu prend 2 pièces alu devant normalement faire un plan de joint, tu voyais le jour entre les 2..........
comment on dit déjà : sur une anglaise, le plus dur est de garder l'eau à l'extérieur et l'huile à l'intérieur...... :D :D
là, tu vois que le pont, mais, c'est pareil sous la boite et le moteur..... :P :P
la 4l, elle pisse pas l'huile, les simca non plus......en tout cas, beaucoup moins.
...on dit aussi (au sujet des Britishs) que c'est un Anglais, LUCAS (mais pas le nôtre, heureusement :D ), l'inventeur du court-circuit :-°
Erwann37
A propos de Lucas :
Lucas the Prince of Darkness
Not many people know that Land Rovers attempted to market a computer. Why did they stop? They could not find a way to get it to leak oil!
A Land Rover doesn't leak oil, it marks it's territory. Did you hear about the man whose Land Rover didn't leak oil? The factory took it backand worked on it until it did.
Did you hear the one about the guy that peeked into a Land Rover and asked the owner "How can you tell one switch from another at night? They all look the same. " - "He replied, "It does not matter which one you use, nothing happens !"
The Lucas motto: "Get home before dark."
Lucas is the patent holder for the short circuit.
Lucas - Inventor of the first intermittent wiper.
Lucas - Inventor of the self-dimming headlamp.
The three position Lucas switch - Dim, Flicker and Off.
The Original Anti-Theft Device - Lucas Electrics.
>Lucas is an acronym for Loose Unsoldered Connections and Splices
Lucas systems actually uses AC current; it just has a random frequency.
"I have had a Lucas pacemaker for years and have never had any trou..."
If Lucas made guns, wars would not start.
A friend of mine told everybody he never had any electric problems with his Lucas equipment. Today he lives in the countryside, in a large manor with lots of friendly servants around him an an occasional ice cold shower...
Back in the 70's, Lucas decided to diversify its product line and began manufacturing vacuum cleaners. It was the only product they offered which did not suck.
Q: Why do the British drink warm beer? A: Because Lucas makes their refrigerators
Alexander Graham Bell invented the Telephone.Thomas Edison invented the Light Bulb. Joseph Lucas invented the Short Circuit.
Recommended procedure before taking on a repair of Lucas equipment: Check the position of the stars,kill a chicken and walk three times clockwise around your car chanting:" Oh mighty Prince of Darkness protect your unworthy servant.."
la traduction haynes pour rester dans le theme :
http://www.mez.co.uk/haynes.html http://www.mez.co.uk/haynes.html
:P :P
rodolpher
Message par rodolpher »
Lol , c'est énorme. J'adore la dernière et celle avec l'aspirateur :P
TRT_1043
Message par TRT_1043 »
Ah bon des fuites d'huile sur les anglaises :)
On a pas a se plaindre sur nos deux minis aucune fuites a deplorer pour le moment, 20w50 oblige!!!
Trt
snowack
Message par snowack »
Tout comme TRT, j'ai deux minis et je n'ai pas de fuites dessus mais par contre pour l'électricité on voit bien que c'est du Lucas, prince des ténèbres.
Erwann37
pas possible, tu es sur qu'il en reste dans le carter ? :P :P
Meme pas au joint spi de la commande de boite ?
:P :P
chappman84
Message par chappman84 »
Tant que ça coule, c'est qu'il y en a encore !
Super ton bedford, le taf est impressionant et la finitions au top ! B)
TRT_1043
Erwann37 a écrit : pas possible, tu es sur qu'il en reste dans le carter ? :P :P
:P :P
Meme pas, sur la mienne le moulin a meme pas 5000 km dc sa peut se comprendre et sur celle de ma copine, 80 000 km idem pas une fuite!
Trt
Tout beau tout neuf :D
